New Phone Charger Uses Built-In Fan to Prevent Overheating and Protect Battery Life
578
Why You'll Love a Cooler, Faster Phone Charger
There's a new type of phone charger that uses a built-in fan to keep your phone from getting hot. At first, this might seem like a bit of a gimmick. But after testing it out for a week, it's clear that this is more than just a novelty. It's a game-changer. This cooler charger not only prevents your phone from overheating, but it also helps to extend the life of your phone's battery.
How Overheating Can Damage Your Phone
Overheating can cause serious damage to your smartphone. This was a lesson learned the hard way after an attempt to edit a 4K video on a hot train while using a regular charger. The phone got so hot that the screen permanently went blank. The repair bill? A whopping $750. Thankfully, the phone was still under warranty.
The Problem with Heat and Batteries
The real issue here is that heat is bad for batteries. High temperatures can speed up the breakdown of lithium-ion cells, which is what powers your phone. This means that over time, your phone's battery will lose its ability to hold a charge. Moreover, the process that regular chargers use to transfer electricity to your phone is inefficient and produces a lot of heat, which can cause your phone to slow down the charging process to protect the battery.
The Convenience of Cooler Chargers
Despite these problems, many of us keep using regular chargers because they're simply more convenient. But now, several companies have started to make chargers with built-in cooling systems. These cool chargers have small heat sinks and quiet fans that move heat away from your phone while it's charging. This keeps the battery cooler and allows it to charge faster.
Keeping Your Phone Cool While Charging
The fan in these cooler chargers is quiet and can be turned off if you prefer. You can also see the time and how much charge each device is drawing, as well as the total power draw. If you find the display too bright or distracting, you can turn it off with the tap of a button.
Not Just for Phones
These cool chargers are compatible with more than just phones. They can also charge watches and earbuds. Some of them even come with a 45W USB-C PD charger included.
Cool Chargers: The Future of Phone Charging?
These cooler chargers might just be the future of phone charging. Already, phone manufacturers like Huawei, Xiaomi, and Oppo support wireless charging speeds of 50W and above. But this is only possible with special chargers that can handle the extra heat. Now, the body responsible for setting standards for these chargers is working on a global 50W standard that could be released by 2028. In order to meet these higher charging rates, manufacturers will likely need to include active cooling in their chargers.
The Verdict
Overall, these cooler chargers are a great improvement on regular chargers. They work just as well on a desk or a nightstand, and they're priced lower than similar products. The built-in fan keeps your phone cool while it charges, which helps to extend the life of your battery and prevent overheating. So if you're in the market for a new charger, consider a cooler one. Your phone (and its battery) will thank you.
